My RV-8 build
Date: 5-6-2012
Number of Hours: 1.00
Manual Reference: Page 7-9
Brief Description: Right wing aileron hinges #3
Haven't had much time in the last week to get at the build. I was at CFB Trenton yesterday and got a solid 4.5 hours in, good flying and some good crosswinds landings.
I received my care package from Van's this past week. With it, I got the replacement W-413A-R plate. After it was deburred, cleaned, and primed, I riveted the pieces together. For those of you not at this stage yet, beware. The AN470AD4-11 rivets are not long enough. You have to go up to -12. After I set the first -11, I realized it wasn't long enough, so it was drilled out and the -12's added.
You have to use an off-set rivet set to set the AN470's here after the fairing and brace are in place. No big deal. I clubbed over one rivet and drilled it out.
In image two, the first rivet on the bottom is a AN426AD4-7. This had to be backriveted in place. After setting the rivets, I shot a dhort blast of self etching primer over the rivets.
I also deburred the bottom skin rivet holes.
Got a batch of proseal in, so I'll finish off installing the inner and outer ribs tomorrow for the left tank.
Inner right wing aileron hinge bracket in place
Properly done this time!
Right wing bottom skin rivet holes deburred.
